| App for figuring safe approach distances? https://brainfiller.com/arcflashforum/viewtopic.php?f=10&t=2682 |
Page 1 of 1 |
| Author: | phanderson [ Thu Mar 21, 2013 4:20 pm ] |
| Post subject: | App for figuring safe approach distances? |
Does anyone know of an app that has been created that will figure the safe approach distances using the new tables in NFPA 70E 2012? Thank you for your responses. |
| Author: | wbd [ Fri Mar 22, 2013 12:16 pm ] |
| Post subject: | |
Not sure what the app would buy you? Why not just use the Notes feature and type the limits from table into a Note? |
| Author: | Bryan Rupert [ Mon Mar 25, 2013 5:43 am ] |
| Post subject: | |
I agree with "wbd" if you need a chart the helps you figure out the PPE level for each HRC go to [url="http://www.FacilityResults.com"]www.FacilityResults.com[/url] and check out the downloads tab. Lots of great tools. |
| Author: | phanderson [ Tue Mar 26, 2013 9:54 am ] |
| Post subject: | |
OK, really good input. One of our Risk Coordinators suggested that I ask for one, I think he envisioned a program that had the tables already incorporated into it, and where you just punch in your specific voltages, etc. and then it figures it. But I see your point, it is almost as easy to use those tools. I'll check them out, thank you so much! |
