Arc Flash Forum
This is why you should avoid installing panels in vaults
https://brainfiller.com/arcflashforum/viewtopic.php?f=11&t=4954
Page 1 of 1
Author:  bbaumer [ Fri Apr 05, 2019 5:06 am ]
Post subject:  This is why you should avoid installing panels in vaults
This panel is only 4 years old. It was installed in an underground vault. The sump pump failed and it was awhile before it was discovered.
http://www.phpbb.com/
