| Etap 7.1 Utility Model https://brainfiller.com/arcflashforum/viewtopic.php?f=15&t=1134 |
Page 1 of 1 |
| Author: | mountaineer [ Wed May 26, 2010 11:09 am ] |
| Post subject: | Etap 7.1 Utility Model |
I have a two pot delta configuration as my utility source, three phase open wye to open delta, 12kv to 120/240. Any suggestions as to how to set up an open delta secondary in Etap? Thanks for any help. |
| Author: | geh7752 [ Wed May 26, 2010 5:05 pm ] |
| Post subject: | |
In the transformer data menu there is selection to specify the type of secondary winding configuration. It allows you to select either delta or wye, open, solid, resistance grounding. |
