It is currently Wed Oct 28, 2026 9:43 pm
 Post subject: SKM Transformer Voltage Label Mix-UP
PostPosted: Sat Aug 14, 2010 6:55 am
I have noticed the cals are correctly calculated for the transformer secondary but the shock hazard warning on their label "shock hazard when cover is removed" always shows the secondary voltage side level and glove rating for the secondary side not the primary side voltage level.
SKM was contacted and said I will have to custom modify the labels for each transformer.Is anyone else having the same problem??
