Arc Flash Forum
EasyPower: Phase Shift Integrity Error around Bus
https://brainfiller.com/arcflashforum/viewtopic.php?f=15&t=135
Page 1 of 1
Author:  ytegegn [ Fri Jun 06, 2008 1:05 pm ]
Post subject:  EasyPower: Phase Shift Integrity Error around Bus
d
Author:  Chet Davis [ Fri Jun 06, 2008 4:51 pm ]
Mr. Solomon:
EasyPower has a phase shift detection algorithm to verify system phasing is correct. You may have a phase shift problem somewhere else on your one-line. You can also turn off the detection in the TOOLS-->OPTIONS controls.
In order to troubleshoot a system, we need access to the EasyPower file, Serial#, version#, etc. If you have a question on EasyPower, the proper place to ask that question is our EasyPower technical support group.
You can reach us at 503-655-5059 or email techsupport@easypower.com
Sincerely,
Chet E. Davis, PE
President
ESA, Inc.
http://www.phpbb.com/
