Arc Flash Forum
EasyPower creating one-line with title block/revision block
https://brainfiller.com/arcflashforum/viewtopic.php?f=15&t=6078
Page 1 of 1
Author:  NeDCE [ Wed May 21, 2025 9:06 am ]
Post subject:  EasyPower creating one-line with title block/revision block
Anyone using EasyPower know how to have a title block/revision block show up on the one-line?
I've gone to tools/drawings/title block defaults and created a template with all the pertinent info, as well as clicked "show title block", but it doesn't show up.
Note that at present, I'm "creating" the one-line by printing to pdf for use in external documents. Does printing out the title block require printing to .dxf, and then converting it in Autodesk or the like? Or should creating a pdf directly from EasyPower include the title block, and I'm just experiencing a glitch?
Author:  NeDCE [ Wed May 21, 2025 2:44 pm ]
Post subject:  Re: EasyPower creating one-line with title block/revision bl
Nevermind, I got the answer from one of their engineers. I didn't realize you had to "create" a drawing of the oneline from the main oneline form. :roll:
http://www.phpbb.com/
