It is currently Thu May 07, 2026 9:30 am
L. Hankle wrote:
Joe Tedesco wrote:
wilhendrix wrote:
Hey, man
SKM jockey for hire
PE in 17 states
SKM jockey for hire
PE in 17 states
PostPosted: Thu May 07, 2026 3:08 am
That’s the kind of inspection story you never forget. Back in the early 70s there were definitely some “creative” installations that somehow made it all the way through to an energized service. Using plumbing elbows in a service raceway sounds funny now, but it also shows why experienced inspectors mattered so much in catching unsafe shortcuts before they turned into bigger problems.
I’ve seen similar discussions from tradespeople over at Plumber Singapore, where plumbers mention running into electrical setups that clearly crossed trade boundaries in the wrong way. It usually comes down to someone trying to make materials “work” instead of using code-approved components. Different era, but the same lesson still applies today.
Looking forward to hearing more of those inspection stories from Pasadena and New Haven. The old field experiences are often better learning material than textbooks.
