It is currently Thu Oct 01, 2026 7:22 am
 Post subject: Fault Current
PostPosted: Tue Apr 14, 2015 9:18 am
I'm wondering if there's any data available that indicates the necessary available fault current, on a 277V system, to blow a hole through the sheathing of a MC cable (#12 awg, 3 conductor).
Assume worst-case - a bolted fault either between phase/ground or phase/sheathing.
If I know that necessary available fault current, I could then conduct a fault current analysis for my particular situation to determine if there's even sufficient current for that to hypothetically occur.
 Post subject: Re: Fault Current
PostPosted: Wed Apr 15, 2015 7:52 pm
There are formulas for metal damage but gas pressure will open it up before it melts through.
