It is currently Thu Oct 29, 2026 1:45 am
 Post subject: Arc Flash Data Collection
PostPosted: Sat Aug 15, 2026 1:03 pm
Hi,
I am curious how much the arc flash study workflow varies from person to person, firm to firm. How are you performing your data collection? Are you doing all validation yourself or relying on field techs or ECs? Are there any tools you use? Are you handing off paper forms to field techs?
I’m working on a tool that would take a non-engineer step by step through what information to collect so engineering time can be spend fully on analysis rather than travel and data collection. I am looking for feedback to see if this can benefit others. It would also integrate nicely with the Easypower 2026 update that allows CSV imports. You can use the app to have someone else collect the data and then import it straight into the model.
Thanks!
 Post subject: Re: Arc Flash Data Collection
PostPosted: Wed Sep 16, 2026 8:06 am
This tool could be helpful. eGalvanic has a tool that handles this as well as field efforts for IR scans. It works with both SKM and EasyPower. It can also assist with developing an EMP for the facility.
