Arc Flash Forum
Cleaning up arc flashed equipment
https://brainfiller.com/arcflashforum/viewtopic.php?f=2&t=1202
Page 1 of 1
Author:  jimmyg34 [ Sun Jul 18, 2010 6:32 pm ]
Post subject:  Cleaning up arc flashed equipment
Looking to clean up steel housing from previously arc flash. The carbon staining seems quite hard to remove. Looking for suggestions from you knowledgeable folks.
Thank you.
Author:  Zog [ Sun Jul 18, 2010 7:59 pm ]
Thank you.
Sandblast and repaint. Or leave it there as a reminder for others.
Author:  dpmac [ Mon Jul 26, 2010 11:26 am ]
I always felt it was best to try to clean it up a bit, or at the very least do something to indicate it has been "seen by others in the past and is not new". We have more then a few customers whose equipment has flashed over often. Its better to open the equipment panel and know the damage is from a previous incident when your trying to troubleshoot the situation. Many times MV insulators flash over and cause major damage to the insulator and minor damage to the cabinet. After replacing the insulators I just circle the arc damage and put a date on it if there is no time to clean it up. IMHO it helps the next guy who is out there in the middle of the night in the rain looking for why the 15kV fuses blew.
Author:  Sparks69 [ Mon Aug 23, 2010 6:35 pm ]
At my work they used a Dry ice sandblast. I dident see it but apparentley the Dry ice disolves and all the contanments end up on the botom of the cabnet and is then wiped out. The end result looks good
Author:  ChevsMark [ Tue Aug 24, 2010 6:14 am ]
[font="Comic Sans MS"][SIZE="3"]I've had good luck with a product called WypAll it is a waterless "hand wipe" which is made by Kimberly-Clark. Then after you use the wipe you let it dry then hit the flashing with some paint. Something else you may try is WD-40 it is amazing what you can do with it. Just spray it on a shop rag and wipe![/size][/font]
http://www.phpbb.com/
