It is currently Fri Oct 23, 2026 11:51 pm
 Post subject: Arc Resistant Simulation
PostPosted: Tue Oct 12, 2010 9:18 am
Hi All
Appreciate If you could help me on how to carryout the Arc Flash/Resistant Simulation using Analysis Softwares to simulate the Enclosure design for the Arc resistant dry type Transformer.
1. What inputs is needed?
2. Which Software is good to carry out simulation ANSYS or CFD
3. I believe this will be a Non Linear analyis. Please Confirm.
4. If this is not done by static analysis, then What are the other options we have?
5. What assumptions should be made in Analysis
6. Do we need to do have any Calculations to find the Pressure applied on the Enclosure? If so how to calculate the pressure?
Any additional inputs is appreciated.
Regards
Raj
PostPosted: Wed Oct 13, 2010 12:26 pm
Appreciate if someone give their comments.
Regards
Raj
