It is currently Fri Nov 06, 2026 3:12 am
 Post subject: Table 130.7(C)(9) note (f)
PostPosted: Fri Mar 11, 2011 9:12 am
This note seems to imply that I would already know the arcing fault current in order to do the allowed HRC reduction. Does it also imply that I have already done an arc hazard analysis? If that is true, does that not imply that I must use the incident energy data for PPE selection?
This seems a small point but I am curious.
PostPosted: Fri Apr 08, 2011 4:05 pm
That's the absurdity of the task matrix table in the first place.
