| Arc Flash Data Collection Form https://brainfiller.com/arcflashforum/viewtopic.php?f=2&t=1996 |
Page 1 of 1 |
| Author: | Flemdog186 [ Tue Jan 24, 2012 3:13 pm ] |
| Post subject: | Arc Flash Data Collection Form |
Would anyone mind sharing a good data collection form that will assist in being sure that all necessary info is obtained from the site. Thanks |
| Author: | jvrielink [ Thu Jan 26, 2012 7:21 am ] |
| Post subject: | |
The IEEE Std 1584 has a list of data you typically need for an arc flash study in the annex. Brainfiller's book also contains a chapter on doing data collection, including helpful tips for when you cannot get it all in one go. Making a form can be easily done in Excel: based on the oneline, put all the components in the rows and data you need in the columns. |
| Author: | Flemdog186 [ Thu Jan 26, 2012 12:59 pm ] |
| Post subject: | |
Thanks J |
| Author: | Bryan Rupert [ Wed Aug 29, 2012 1:52 pm ] |
| Post subject: | |
Flemdog186 wrote: Would anyone mind sharing a good data collection form that will assist in being sure that all necessary info is obtained from the site. Thanks Facility Results offer the premier arc flash data gathering software tool. It is called FlashTrack. It is simple to use and improves the data collection process, label installation and change management process. FlashTrack works well with SKM, EasyPower, ETap and others. When collecting the data it creates a valuable one-line, label installation report that includes photos and fully catalogs Just Google "flashtrack data collection" and it will pop up. |
| Author: | arcad [ Thu Aug 30, 2012 1:12 pm ] |
| Post subject: | |
Check http://www.arcadvisor.com/faq/arc-flash-data-collection-form.html for sample arc flash data collection form. |
| Author: | Bryan Rupert [ Thu Mar 14, 2013 8:08 am ] |
| Post subject: | |
"FlashTrack" for the data collection. It is easy to use and a qualified worker can quickly collect all the data needed for the engineer it do the analysis using (in our case) SKM. Note: FlashTrack is not for doing calculations, it was designed for the qualified worker to capture the data needed to model the system. [ATTACH=full]295[/ATTACH] |
