Arc Flash Forum
Incident Energy
https://brainfiller.com/arcflashforum/viewtopic.php?f=2&t=352
Page 1 of 1
Author:  Vica1ME [ Fri Feb 27, 2009 9:34 am ]
Post subject:  Incident Energy
We express available incident energy in calories/square-cm. I'm a bit
confused about the square-cm. I know how to convert watt-seconds to
joules to calories of heat. How does the square-cm factor into the
equation?
Author:  Zog [ Fri Feb 27, 2009 9:47 am ]
equation?
Think of Watt-seconds as energy released, when you talk about J or Cal/cm2 it is refering to that heat on a recieving surface, so to measure that you need to define the area of the recieving surface.
http://www.phpbb.com/
