| Fault Current https://brainfiller.com/arcflashforum/viewtopic.php?f=2&t=3668 |
Page 1 of 1 |
| Author: | Vica1ME [ Tue Apr 14, 2015 9:18 am ] |
| Post subject: | Fault Current |
I'm wondering if there's any data available that indicates the necessary available fault current, on a 277V system, to blow a hole through the sheathing of a MC cable (#12 awg, 3 conductor). Assume worst-case - a bolted fault either between phase/ground or phase/sheathing. If I know that necessary available fault current, I could then conduct a fault current analysis for my particular situation to determine if there's even sufficient current for that to hypothetically occur. |
| Author: | PaulEngr [ Wed Apr 15, 2015 7:52 pm ] |
| Post subject: | Re: Fault Current |
There are formulas for metal damage but gas pressure will open it up before it melts through. |
