Arc Flash Forum
Comprehensive Short Circuit Studies
https://brainfiller.com/arcflashforum/viewtopic.php?f=2&t=5149
Page 1 of 1
Author:  vipparthi uttej [ Sat Aug 03, 2019 9:24 am ]
Post subject:  Comprehensive Short Circuit Studies
How does SKM Software calculate the bolted fault current for arc flash studies? What are the steps of calculating short circuit current by using comprehensive short circuit studies?
Author:  Robertefuhr [ Mon Aug 05, 2019 9:15 am ]
Post subject:  Re: COMPREHENSIVE SHORT CIRCUIT STUDIES
I would suggest that you read the user guide SKMInclude_PTW Userguide.pdf and tutorial SKMInclude_PTW Tutorial.pdf. There is a ton of information that will educate you on how the calculations are done. If you have a valid Maintenance Agreement and are up to date with your maintenance fees, then you can go to their website and down load these two documents.
http://www.phpbb.com/
