Arc Flash Forum
Insulating feeder wires/term points in a switchboard/panel
https://brainfiller.com/arcflashforum/viewtopic.php?f=2&t=5648
Page 1 of 1
Author:  wsorrell1970 [ Wed Jan 04, 2023 12:33 pm ]
Post subject:  Insulating feeder wires/term points in a switchboard/panel
I was wondering if a Switchboard or Panelboard has its feeder wires insulated and termination points shielded with plastic/insulation, then the Arc Flash rating of the switchboard/panelboard should be the same as though nothing was insulated?
The cal/cm2 number would not change. I'm thinking the insulation might protect against a shock, but not an Arc Flash explode.
Just asking if this assumption is correct.
http://www.phpbb.com/
