It is currently Sat Oct 17, 2026 2:13 am
 Post subject: Osha 1910.269
PostPosted: Wed Nov 12, 2008 6:05 am
I heard that OSHA 1910.269 had been going through the revision / approval process for the past few years. Does anyone know if the new version has been completed / adopted and does it say anything new about arc flash and PPE?
PostPosted: Wed Nov 12, 2008 7:26 am
Still a work in progress.
PostPosted: Wed Nov 12, 2008 10:12 am
I know OSHA moves very slowly but any idea on when this revision might be done? Months, Years, Our lifetime?
PostPosted: Wed Nov 12, 2008 12:14 pm
Also... is there any specific reference in OSHA to either
Arc Flash or
FR clothing ?
All I can find is 1910.335 "wear PPE that is appropriate"
leaving "appropriate" up to 70E, IEEE 1584 and the other standards.
Thanks for the help!
PostPosted: Wed Nov 12, 2008 1:22 pm
They were saying it was to change by the end of 2007, instead they made changes to the installation requirements, I think the 70E changes will be rolled into the general electrical sections first, then into 269 because they have to cover 70E and NESC which is in flux right now. That is just what I expect to happen, I dont have any inside info on a timetable or anything.
PostPosted: Wed Nov 12, 2008 7:46 pm
I don't think OSHA would be able to put in law the requirements for 'no live work' the same as NFPA70E. Typically, you don't see regulations that disruptive to normal business flow in OSHA.
PostPosted: Fri Nov 14, 2008 6:44 am
Does anyone know if the term "arc flash" or "FR clothing" even appears in the OSHA regulations. I can't seem to find it.
