It is currently Mon Sep 28, 2026 10:19 am
 Post subject: Wind Turbine Modelling
PostPosted: Fri Apr 17, 2020 9:31 am
Hi,
I have been given an equivalent diagram for a wind turbine and want to calculate an X/R ratio for the turbine in my ETAP model. What values do I need to consider here?
I have attached a picture of the diagram.
Also, do you all consider low voltage ride through in an arc flash study?
