It is currently Fri Oct 07, 2022 8:53 am
ekstra   ara
 Post subject: NENS 09 Australian AF Calculation method
PostPosted: Mon May 17, 2021 9:25 am
Is Anyone out there familiar with the NENS 09 Australian AF Calculation method?
This method was published in the "ENA NENS 09-2014 National Guideline PPE Arc" Guideline that's used in Australia. (See equations in attached image)
They list the methodology and equations but I don't see a breakdown of the method limitations.
For example, in IEEE 1584 there is a disclaimer saying the applicable voltage, fault currents, etc that the method is valid for.
Based on the citings this method may have originated from the following document but I can't seem to find it anywhere online.
EESA Electrical Arcing Hazards - A paper by Dr. David Sweeting (Sweeting Consulting) and Professor Tony Stokes (Electrical Engineering University of Sydney) presented at the EESA Conference in Sydney on 12 August 2004;
If anyone can shed some light on this or point out the limitations of the method that would be appreciated!
I realize the method is older in comparison to IEEE 1584 but I'm interested to see how the assumptions of this method compare to the updated IEEE 1584 model.
You do not have the required permissions to view the files attached to this post.
 Post subject: Re: NENS 09 Australian AF Calculation method
PostPosted: Mon Nov 15, 2021 5:12 am
I too would be interested to know the limitations / applicability, especially in relation to voltage (i.e. is there a minimum and maximum voltage range stated)?
