It is currently Sun Oct 25, 2026 5:57 am
 Post subject: ETAP ArcFault - NESC clarification
PostPosted: Fri Feb 18, 2022 11:01 am
ETAP says that the ArcFault module was developed to be in compliance with NESC (amongst other standards). Yet, the two calculation methods provided are EPRI and Terzija / Konglin.
If ArcFault does not use the NESC lookup method, then what part of NESC does ETAP use in the calculations? I suppose the gap and approach distances?
Thank you. By the way, I don't have the ArcFault module yet, so cannot play around.
 Post subject: Re: ETAP ArcFault - NESC clarification
PostPosted: Tue Mar 01, 2022 7:21 am
Why don't you ask ETAP your question and post the reply here?
