Arc Flash Forum
Line-ground fault current on a corner grounded delta system
https://brainfiller.com/arcflashforum/viewtopic.php?f=23&t=5780
Page 1 of 1
Author:  arkanos [ Thu Apr 04, 2024 5:17 am ]
Post subject:  Line-ground fault current on a corner grounded delta system
I'm calculating the 3 phase and ground fault current on a 23kV corner-grounded delta system in Aspen. I have not been able to determine how to model such a transformer in Aspen; it is currently modeled as an ungrounded delta.
My thinking is that the line-line fault current on an ungrounded delta would be equivalent to a line-ground fault current on a corner grounded delta. Can anyone weigh in? Or provide guidance on how to calculate such a fault current?
http://www.phpbb.com/
