Arc Flash Forum
Bolted Pressure Switch
https://brainfiller.com/arcflashforum/viewtopic.php?f=23&t=6402
Page 1 of 1
Author:  arcflashprimero [ Mon Feb 16, 2026 11:23 am ]
Post subject:  Bolted Pressure Switch
any tips on modeling an Eaton bolted pressure switch? switchboard is using a BPS as the main device with ARMS mode. would this be modeled just as a fuse?
Author:  mpparent [ Tue Feb 17, 2026 7:18 am ]
Post subject:  Re: Bolted Pressure Switch
I think Eatons' offering is actually an arc reduction relay tied to the BPS. In my opinion, you'll model two things:
1. Fuse
2. The arc reduction relay with trip times from the manufacturer. You may have to create your own library file for this one, unless SKM, Easypower, etc. have a model file you can use.
Mike
http://www.phpbb.com/
