| Size for Arc flash labeling https://brainfiller.com/arcflashforum/viewtopic.php?f=24&t=5358 |
Page 1 of 1 |
| Author: | Nerf [ Mon Sep 14, 2020 9:27 am ] |
| Post subject: | Size for Arc flash labeling |
Hello, good morning, this a exist one standar for regule the size in the arc flash labeling (for example 4" x 6", 6" x 6", etc.) Excuse me, my english is not perfect. |
| Author: | JBD [ Wed Sep 16, 2020 7:47 am ] |
| Post subject: | Re: Size for Arc flash labeling |
There is no standard size. As Mike said, 4 inches by 6 inches is commonly used. |
| Author: | rn70410 [ Mon Sep 21, 2020 2:37 pm ] |
Hello, my plant's labels are all around 5-1/4" x 4" |
| Author: | JJH [ Tue Sep 22, 2020 4:52 am ] |
I typically use 4" x 6". However, these won't fit on some of the smaller disconnects. In that case, I use a 2 1/4" x 3" label. |
| Author: | wilhendrix [ Tue Sep 22, 2020 6:44 am ] |
What really matters is that the label font is large enough to be read, and that the labels are put on the device where they are easy to see. |
| Author: | Leonard [ Mon Sep 28, 2020 8:03 am ] |
Hello Nerf, as per the others the 4" x 6" is very common. However you have to remember that there is allot of us baby boomers out there in which our eyesite is challenged. Take a look at your work force and see what the average age is of the workers who would be referencing the labels and make your decision from there. I hope that this helps |
| Author: | engrick [ Tue Sep 28, 2021 10:25 am ] |
I use 4"x4" with the minimum info - bigger labels may not fit on small equipment |
| Author: | sparkie001 [ Fri Jun 09, 2023 10:50 am ] |
I know this is an ancient thread but for future reference ANSI Z535.4 has a table of recommended letter heights vs viewing distance. |
