| Author |
Message |
BarkFlash
Post subject: "sufficient durability to withstand the environment involved Posted: Wed Mar 04, 2026 10:14 am |
Joined: Wed Nov 23, 2022 8:53 am Posts: 28 Location: Indiana
Section 110.21 (B) is quote above in the title and is required for field applied Arc Flash Labels.
What Tips & Tricks do you guys use to address this requirement for labels installed outside and/or exposed to sunlight? We have been using a clear, UV resistant paint sprayed over the labels. But recently I saw a label we installed in 2022 and it was 75-90% disintegrated!! This makes me second guess this method, looking for other options.
Thanks in advance!
_________________ Steward of the magic smoke genie.
| Top |
bbaumer
Post subject: Re: "sufficient durability to withstand the environment invo Posted: Thu Mar 05, 2026 3:11 am |
| Arc Level |
I print indoor labels on a color laser printer and they work fine for that BUT I have the same issue as you with outdoor labels. They fade out very quickly. The label stock isn't the problem, it's the color laser printer ink that doesn't hold up.
I have to get someone to print outdoor labels to a Brady printer. Those hold up very well.
_________________ Retired but I might visit once in awhile
| Top |
Page 1 of 1
[ 2 posts ] |
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot post attachments in this forum
