Arc Flash Forum
Article 2: Are You Working on the Right Equipment? The Danger of “Look-Alikes”
https://brainfiller.com/arcflashforum/viewtopic.php?f=30&t=1710
Page 1 of 1
Author:  A2003 [ Tue May 10, 2011 6:10 am ]
Post subject:  Article 2: Are You Working on the Right Equipment? The Danger of “Look-Alikes”
Don’t bet your life that the labeling on equipment is correct.
Always “Test Before You Touch.”
It is important to remember that hazardous energy control measures
cannot protect you if you work on the wrong piece of equipment.
arc flash risk assessment methodology.pdf [106.92 KiB]
Downloaded 891 times
Author:  QuadTech [ Fri Jun 17, 2011 12:33 pm ]
Excellent point! Labeling wears off, and can be incorrectly replaced. You want to know what to expect when you are working with a piece of equipment. That means you have to be 100% sure of what that equipment is!
http://www.phpbb.com/
