It is currently Mon Oct 19, 2026 2:58 pm
 Post subject: Article 2: Are You Working on the Right Equipment? The Danger of “Look-Alikesâ€�
PostPosted: Tue May 10, 2011 6:10 am
Don’t bet your life that the labeling on equipment is correct.
Always “Test Before You Touch.�
It is important to remember that hazardous energy control measures
cannot protect you if you work on the wrong piece of equipment.
arc flash risk assessment methodology.pdf [106.92 KiB]
Downloaded 873 times
PostPosted: Fri Jun 17, 2011 12:33 pm
Excellent point! Labeling wears off, and can be incorrectly replaced. You want to know what to expect when you are working with a piece of equipment. That means you have to be 100% sure of what that equipment is!
