Arc Flash Forum
2 Weeks???
https://brainfiller.com/arcflashforum/viewtopic.php?f=30&t=1907
Page 1 of 1
Author:  Zog [ Fri Nov 04, 2011 6:24 am ]
Post subject:  2 Weeks???
Here is one y'all might enjoy. Customer had a switchgear blow up (Can't get into details) and needed to have gear rebuilt to the same specs, no problem, we do that all the time, trick here was they needed it back in 2 weeks. Was not easy, but done, before and after photos attached.
U.K. Arc Flash Seminar.pdf [3.3 MiB]
Downloaded 5835 times
Author:  Kimo [ Fri Nov 04, 2011 6:36 am ]
Amazing!
That is amazing, I would like to know how you pulled that off.
Author:  Vincent B. [ Fri Nov 04, 2011 7:03 am ]
I hope they had the specs somewhere else than in/on the gear itself :)
The second and seventh top panels in the rebuilt photo don't seem properly latched: there's a slight angle visible at the top. Is it because they weren't yet commissioned when the photo was taken?
Author:  alf [ Wed Dec 07, 2011 4:57 pm ]
Photos
It appears that the after photo is the left one. Correct?
Author:  Zog [ Thu Dec 08, 2011 8:36 am ]
No, the right photo is after the repairs.
Author:  Legion [ Thu Dec 08, 2011 12:47 pm ]
Impressive turn around time.
Author:  Gary B [ Mon May 27, 2013 7:48 am ]
Looks like the repair included upgraded SEL relays. Merely specifying the relays usually takes more than two weeks, somebody must've known what they needed in advance :)
(It sure looks good)
Author:  Zog [ Tue May 28, 2013 6:55 am ]
We have hundreds of them in stock, no time to wait 2 weeks when things like this happen.
http://www.phpbb.com/
