It is currently Sat Oct 03, 2026 9:55 am
Will you ever use the new 2015 NFPA 70E PPE Tables?
Yes 45%  45%  [ 22 ]
No 55%  55%  [ 27 ]
Total votes : 49
 Post subject: 2015 Edition of NFPA 70E NEW PPE Category Tables
PostPosted: Sun Dec 07, 2014 7:12 pm
Since the 2015 Edition of NFPA 70E did away with Hazard Risk Tables and replaced them with PPE tables, will you ever use the new PPE Tables?
Yes
No
 Post subject: Re: 2015 Edition of NFPA 70E NEW PPE Category Tables
PostPosted: Mon Dec 08, 2014 9:07 am
I think the new tables are awful. The versions in the 1st and 2nd drafts weren't bad. They were similar to this:
https://www.osha.gov/pls/oshaweb/owadis ... &p_id=9873
under Table 1.
Then something happened. We have a definition of "normal operation" in 130.2(A)(2) for instance but then it is never used in the tables.
OSHA gives about a dozen different task categories and so did the original drafts of 70E-2015. But the final version includes over 2 dozen entries many of which are very confusing in terms of what they are intended to cover.
PostPosted: Mon Dec 08, 2014 4:47 pm
I am under the obligation of training apprentices and journeyman in the latest rules and regulations so I have no choice but to introduce them to the new PPE Category Table of the 2015 NFPA 70E
