It is currently Fri Nov 06, 2026 6:54 am
Have you ever used any information from any of the informative annexes in NFPA 70?
Yes 88%  88%  [ 22 ]
No 12%  12%  [ 3 ]
We use a different standards 0%  0%  [ 0 ]
Doesn't apply 0%  0%  [ 0 ]
Total votes : 25
 Post subject: NFPA 70E - Informative Annexes
PostPosted: Sun Apr 08, 2018 2:41 pm
Have you ever used information from any of the informative annexes found in NFPA 70?
Yes
No
Doesn't apply
If so, what information/annex(s) did you use?
If you use a different standard such as CSA Z462 etc., which one do you use?
 Post subject: Re: NFPA 70E - Informative Annexes
PostPosted: Sun Apr 08, 2018 7:59 pm
Our PPE selection was based on the 12 and 40 cal/cm^2 method.
