It is currently Fri Nov 27, 2020 6:19 pm
What is your company/client’s policy for operating non load break disconnect switches under load?
NEVER operate a non load break disconnect under load even to save a life.
Advise employees that it is their personal choice to risk operating a non load break disconnect under load in order to save a life.
Operate a non load break disconnect if that is the quickest means to save a life.
Your plant has E-Stops within easy reach of every disconnect so this question is irrelevant.
Your employees never violate safety policy and never make mistakes in lockout procedures.
Something else - curious what that would be
You may select 1 option
View results
 Post subject: Your Policy - Operating disconnect under load to save life?
PostPosted: Sun Nov 15, 2020 3:46 pm
A great ongoing discussion regarding operating non-load break disconnect switches UNDER LOAD including if it is necessary to save a life. It was suggested to ask the following question below as a "Question of the Week"
The full thread can be found here. VIEW Disconnect Conversation Here Feel free to jump into the conversation.
NOTE: Legal stuff. Do not take the results of this survey as a recommendation regarding operating disconnects.
Here is this week’s question:
-NEVER operate a non load break disconnect under load even to save a life.
-Advise employees that it is their personal choice to risk operating a non load break disconnect under load in order to save a life.
-Operate a non load break disconnect if that is the quickest means to save a life.
-Your plant has E-Stops within easy reach of every disconnect so this question is irrelevant.
-Your employees never violate safety policy and never make mistakes in lockout procedures.
-Something else - curious what that would be.
Report this post
 Post subject: Re: Your Policy - Operating disconnect under load to save li
PostPosted: Mon Nov 16, 2020 6:03 am
Not really sure why this would be an issue with load break switches.
Report this post
PostPosted: Mon Nov 16, 2020 6:13 am
Thanks! That was part of the original thread but wasn't clear here. I added "non-load break" to the question.
Report this post
You can post new topics in this forum
You can reply to topics in this forum
