It is currently Sun Jan 17, 2021 5:44 pm
Do you wear arc rated clothing around electrical hazards LESS THAN 1.2 cal/cm^2
No
Yes – sometimes
Yes - always
You may select 1 option
View results
 Post subject: Wearing Arc Rated Clothing – Hazard less than 1.2 cal/cm^2
PostPosted: Sun Jan 10, 2021 1:33 pm
Arc rated clothing is to be worn when the incident energy level is greater than 1.2 cal/cm^2. NFPA 70E specifically states:
130.7(C)(6) Body Protection. Employees shall wear arc-rated clothing whenever there is possible exposure to an electric arc flash above the threshold incident energy level for a second-degree burn [1.2 cal/cm^2]
Here is the first question of the week for 2021:
Do you/employees/clients wear arc rated clothing around electrical hazards LESS THAN 1.2 cal/cm^2?
No
Yes – sometimes
Yes - always
Stories are always welcome!
Happy New Year!
Report this post
You can post new topics in this forum
You can reply to topics in this forum
