| Current Limiting Devices https://brainfiller.com/arcflashforum/viewtopic.php?f=33&t=1483 |
Page 1 of 1 |
| Author: | Jim Phillips (brainfiller) [ Sun Jan 09, 2011 6:05 pm ] |
| Post subject: | Current Limiting Devices |
Do you use current limiting devices to reduce the arc flash incident energy? |
| Author: | Oliche121 [ Mon Jan 17, 2011 1:56 am ] |
| Post subject: | |
Which current limiting products to reduce arc Flash risk ?? Which current limiting products are allowed for arc flash reduction ? Do they request to succed some tests ? |
| Author: | haze10 [ Mon Jan 17, 2011 10:54 am ] |
| Post subject: | |
Current Limiting Fuses and Breakers reduce the let through fault current. By reducing the fault current, you reduce the Incidend Energy (arc flash). |
| Author: | Jim Phillips (brainfiller) [ Mon Jan 17, 2011 2:24 pm ] |
| Post subject: | |
Oliche121 wrote: Which current limiting products are allowed for arc flash reduction ?
Do they request to succed some tests ? IEEE 1584 did some testing with current limiting fuses and published a few equations. Properly applied C.L. breakers and fuses can significantly reduce the incident energy. |
