It is currently Tue Oct 20, 2026 11:03 pm
Do you have the 2012 Edition of NFPA 70E?
Yes 56%  56%  [ 29 ]
No 44%  44%  [ 23 ]
Total votes : 52
 Post subject: Do you have the 2012 Edition of NFPA 70E?
PostPosted: Sun Oct 09, 2011 3:08 pm
Do you have the NEW 2012 Edition of NFPA 70E yet?
  • Yes
  • No
PostPosted: Sun Oct 09, 2011 4:51 pm
Good edit
In addition to the many technical changes, the committee did a good job with the structure of the document. Sections were moved to make the logic flow more easily; tables were expanded. Footnotes were expanded or compressed.
PostPosted: Mon Oct 10, 2011 6:28 am
In transit
My copy is ordered, but not yet received. I will vote when my copy is in hand.
PostPosted: Wed Oct 12, 2011 5:15 am
Received 70E Standard
Ordered Oct 6, received Oct 11, via UPS. Now that I have the 70E STANDARD I need to order the 70E HANDBOOK to help me understand the STANDARD.
Per NFPA, the 70E HANDBOOK is available October 21.
Will there be a COMPACT EDITION too for portability?
PostPosted: Wed Oct 12, 2011 12:42 pm
Not yet, but I should get it in the following weeks.
Then adapt myself to it.
PostPosted: Tue Oct 18, 2011 4:04 pm
NFPA does not publish a 70E Pocket Guide, or at least not yet. There is a small book (approximately 4 x 6 inches) that is published by Jones and Bartlett Publishers. The title is “Ugly's Electrical Safety and NFPA 70E.� The current book is based on the 2009 Edition. The Ugly’s book based on the 2012 Edition is not set to be released until March, 2012. While I am not the original author of this book, I was contracted to update the book to the new 2012 Edition of 70E. I was hoping the release date would be this year because I finished my part three or four months early.
PostPosted: Wed Oct 19, 2011 7:36 am
Nfpa/ieee
WE subscribe to NFPA and IEEE explore, we have access to all ( I think )
documents. I would like to see other organizations offer the same setup.
Jeff
PostPosted: Fri Oct 21, 2011 10:29 am
I received my copy the same day I received my copy of Jim's new book. Now I have something to read with each eye.
