| What Arc Flash Software Do You Use? https://brainfiller.com/arcflashforum/viewtopic.php?f=33&t=2660 |
Page 1 of 1 |
| Author: | Jim Phillips (brainfiller) [ Sun Mar 10, 2013 4:00 pm ] |
| Post subject: | What Arc Flash Software Do You Use? |
Which of the following arc flash software have you or your consultants used? SELECT ALL THAT APPLY
| Author: | Flashback [ Mon Mar 11, 2013 6:53 am ] |
| Post subject: | |
SynerGEE |
| Author: | Larry Stutts [ Mon Mar 11, 2013 7:00 am ] |
| Post subject: | |
I am curious. Is there a particular reason you have chosen the software you use over the others that are available? |
| Author: | Juan Lopez [ Mon Mar 11, 2013 8:50 am ] |
| Post subject: | |
Arcad is really user friendly and data entry is intuitive and very accesible. One advantage is their tech support really help me to understand a couple of questions generated during the process. Pricing is very affordable too. |
| Author: | stevenal [ Tue Mar 12, 2013 9:39 am ] |
| Post subject: | |
IEEE Excel spreadsheet. |
| Author: | wbd [ Tue Mar 12, 2013 4:29 pm ] |
| Post subject: | |
I have been using EasyPower since around 1998. I had looked at EDSA, ETAP and SKM and at that time it seemed the most user friendly. I even took a trip to see Conrad St. Pierre and see it in use by a well known electrical engineer. So the familiarity plus excellent tech support keeps me using it. |
| Author: | Bryan Rupert [ Thu Mar 14, 2013 8:03 am ] |
| Post subject: | |
We use two software packages. The 1st is "FlashTrack" for the data collection. It is easy to use and a qualified worker can quickly collect all the data needed for the engineer it do the analysis using (in our case) SKM. Note: FlashTrack is not for doing calculations, it was designed for the qualified worker to capture the data needed to model the system.[ATTACH=full]293[/ATTACH] |
