Arc Flash Forum
DC Electric Shock
https://brainfiller.com/arcflashforum/viewtopic.php?f=33&t=2743
Page 1 of 1
Author:  Jim Phillips (brainfiller) [ Sun May 05, 2013 11:13 am ]
Post subject:  DC Electric Shock
I have posted several questions about electric shock in the past. Here is a new one based on a recent conversation about the subject.
Have you ever been shocked by a DC system? If the answer is yes, what was the voltage?
  • Yes
  • No
Author:  A King [ Mon May 06, 2013 6:51 am ]
Yes, 24 volt.
I was replacing a smashed photo eye; I picked it up twice before I realized I was being shocked. :oops: The equipment operators thought it was hilarious; obviously they had all already touched it too.
Author:  hewl35 [ Mon May 06, 2013 6:56 am ]
  • Yes
  • No
544 volts.
Author:  Larry Stutts [ Mon May 06, 2013 6:57 am ]
90, 180, 240, 500 - I used to work on Inverters and DC drives (component level repairs and field service). I can't even count how many times I was shocked off the case of an ungrounded oscilloscope when connected to the armature
Author:  Zog [ Mon May 06, 2013 6:57 am ]
Yes, LA class submarine battery, yes the whole string. Voltage classified ;)
Author:  Michael McCravey [ Tue May 07, 2013 4:19 am ]
250VDC
Author:  JKlessig [ Tue May 07, 2013 8:51 am ]
125 DC, to the back of the hand, off of the back of a GE protective relay panel door. I grew to hate that dual "door behind door" setup for their gas turbine packages, but it did conserve on the space. Now it would all be replaced by one relay.
http://www.phpbb.com/
