Arc Flash Forum
Arc Flash Labels above 40 cal/cm^2
https://brainfiller.com/arcflashforum/viewtopic.php?f=33&t=3694
Page 1 of 1
Author:  Jim Phillips (brainfiller) [ Sun May 10, 2015 11:50 am ]
Post subject:  Arc Flash Labels above 40 cal/cm^2
This week's question once again refers to the informational note found in NFPA 70E that states:
130.7 Informational Note No. 3: When incident energy exceeds 40 cal/cm^2 at the working distance, greater emphasis may be necessary with respect to de-energizing before working within the limited approach boundary of the exposed electrical conductors or circuit parts.
Where the calculated incident energy exceeds the 40 cal/cm^2 limit from Informational Note 3, many arc flash labels use a Red background with white "Danger" as the signal word. However many of these labels also have language that states:
"No Safe PPE Available"
or something similar even though PPE is available with arc ratings upwards of 100 cal/cm^2.
The concern continues to be two things, the perceived thought of blast pressure and legal aspects of a standard containing a reference to 40 cal/cm^2 in this context even though it is an informational note.
Here is this week's question:
For locations > 40 cal/cm^2, which of the following are on your/client's label
Danger
No Safe PPE Exists
Energized work prohibited
None of these
Something else
We don't have locations > 40 cal/cm^2
Select up to THREE options.
http://www.phpbb.com/
