Arc Flash Forum
New Labeling Strategy - 40 cal/cm2 deleted?
https://brainfiller.com/arcflashforum/viewtopic.php?f=33&t=4331
Page 1 of 1
Author:  Jim Phillips (brainfiller) [ Sun Mar 12, 2017 2:04 am ]
Post subject:  New Labeling Strategy - 40 cal/cm2 deleted?
This week’s question is a follow up to last week regarding the likely deletion of the 40 cal/cm2 note from the 2018 NFPA 70E.
Many use the signal word DANGER when the incident energy is greater than 40 cal/cm2. A questions was raised by one of our forum members to see if this practice may change with the deletion of the 40 cal/cm2 note.
This week’s question is specifically about labeling.
Will you/client(s) change labeling practices when the 40 cal/cm2 is deleted?
No/Probably not
Yes/Probably
Doesn’t Apply to Me
http://www.phpbb.com/
