| Author |
Message |
Jim Phillips (brainfiller)
Post subject: Have you/client had a DC arc flash? Posted: Sun Jan 21, 2018 10:39 am |
| Plasma Level |
Joined: Mon Sep 17, 2007 5:00 pm Posts: 1738 Location: Scottsdale, Arizona
This is the last question in the series about DC arc flash.
Have you/your client ever had a "significant" DC arc flash No Yes – equipment damage Yes – injury Yes - equipment damage and injury
*significant refers to equipment damage and/or injury
Stories are always welcome.
| Top |
bbaumer
Post subject: Re: Have you/client had a DC arc flash? Posted: Mon Jan 22, 2018 4:18 am |
| Arc Level |
Not that I know of.
I've stupidly reconnected the - terminal first on a car battery and then shorted the + terminal to the body via a wrench before. Does that count?
_________________ Retired but I might visit once in awhile
| Top |
bbaumer
Post subject: Re: Have you/client had a DC arc flash? Posted: Mon Jan 22, 2018 7:31 am |
| Arc Level |
Oh, and no injury to speak of other than my pride was a little hurt.
| Top |
rmgbob
Post subject: Re: Have you/client had a DC arc flash? Posted: Mon Jan 22, 2018 9:49 am |
The manufacturers technician doing start-up on a newly installed unit set his wrench down across the lugs of the battery breaker. Nothing left of the wrench, equipment damage and soiled pants.
| Top |
ivanpulido92
Post subject: Re: Have you/client had a DC arc flash? Posted: Tue Jan 23, 2018 1:20 pm |
Yes... Once a technician was connecting the battery bank for a solar power plant´s protection system (relays) , then when He tried to make the last connection He shorted all the batteries so it was a pretty good flash. The worker had no injury so, it was an economic experience.
| Top |
PaulEngr
Post subject: Re: Have you/client had a DC arc flash? Posted: Thu Jan 25, 2018 3:18 pm |
| Plasma Level |
Joined: Tue Oct 26, 2010 9:08 am Posts: 2178 Location: North Carolina
Isn't half the fun of working on DC flashing over a motor/generator and removing all the hair on your arms?
I've seen plenty of "aftermath" and even had a few buddies who got a "summer hair cut" (hair burned off their arms and maybe their face) from flashovers but I have not seen any injuries yet. In the mining industry commonly the largest DC motor they use is a GE MD824 and the associated generator which has a stall current of around 6000 A but at something like 12 VDC, and a name plate voltage of 90 VDC.
When it comes to DC generators and motors, it seems like nobody ever wants to take the time to blow the carbon dust out or tries to see how long they can go before something flashes over. It can get ugly but usually the damage is relatively minor.
When it comes to DC motors ang generators as far as I've seen the biggest hazard seems to be the danger of failure of the banding on the commutator. When this fails, the commutator flies apart and the level of destruction is scary. A single motor or generator can destroy multiple others around it in a larger MG set.
| Top |
Page 1 of 1
[ 6 posts ] |
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot post attachments in this forum
