| NFPA 70E - Informative Annexes https://brainfiller.com/arcflashforum/viewtopic.php?f=33&t=4620 |
Page 1 of 1 |
| Author: | Jim Phillips (brainfiller) [ Sun Apr 08, 2018 2:41 pm ] |
| Post subject: | NFPA 70E - Informative Annexes |
Have you ever used information from any of the informative annexes found in NFPA 70? Yes No We use a different standard Doesn't apply If so, what information/annex(s) did you use? If you use a different standard such as CSA Z462 etc., which one do you use? |
| Author: | JBD [ Sun Apr 08, 2018 7:59 pm ] |
| Post subject: | Re: NFPA 70E - Informative Annexes |
Our PPE selection was based on the 12 and 40 cal/cm^2 method. |
