Arc Flash Forum
Short Circuit Calculations: ANSI/IEEE or IEC
https://brainfiller.com/arcflashforum/viewtopic.php?f=33&t=5171
Page 1 of 1
Author:  Jim Phillips (brainfiller) [ Sun Sep 15, 2019 12:47 am ]
Post subject:  Short Circuit Calculations: ANSI/IEEE or IEC
I just arrived in Geneva, Switzerland for IEC meetings which prompted this week's question. It is about IEC vs. ANSI/IEEE Standards for short circuit current calculations.
Depending on which method is used, the results can vary a bit which may also affect the calculated incident energy.
Here is this week's question:
Which short circuit calculation method do you use?
ANSI/IEEE
IEC
Both
Other (please describe)
I Don't Perform Studies
Author:  arcad [ Sun Sep 15, 2019 7:41 pm ]
Post subject:  Re: Short Circuit Calculations: ANSI/IEEE or IEC
ANSI/IEEE
IEC
Both
I prefer comprehensive method factoring in all the equipment active, reactive impedance and contribution to fault current. Also, I find it important to know the range of available fault current (min - max) and take into account arc duration so I can identify worst case arc flash scenario. Incident energy alone is meaningless unless you know how fast that energy has been delivered. Jim, let me know please if I can be of any help elaborating on or escalating this issue to decision making authorities.
http://www.phpbb.com/
