Arc Flash Forum
Have you ever been burned (from any source)
https://brainfiller.com/arcflashforum/viewtopic.php?f=33&t=5182
Page 1 of 1
Author:  Jim Phillips (brainfiller) [ Sun Oct 06, 2019 2:09 pm ]
Post subject:  Have you ever been burned (from any source)
PPE and Arc Flash Studies are about protecting the worker from burn injury as a result of an arc flash.
This week’s question is about burn injury from ANY source. Arc flash, fire, hot surface etc.
Have you ever been burned? (from any source)
Yes – First Degree
Yes – Second Degree
Yes – Third Degree
No
(Stories are encouraged!)
Author:  Guest [ Mon Oct 07, 2019 7:17 am ]
Post subject:  Re: Have you ever been burned (from any source)
Soldering iron - first degree and second degree
Sunburn - first degree and borderline second degree
Campfire - both second degree and first degree
Author:  arcad [ Fri Oct 11, 2019 6:39 am ]
Gas stove (probably the first bright memory from childhood)
Boiled water
СаС2 (aka Carbide) water mixture explosion (burnt eyebrows, eyelashes and fingers)
Electric heater
Campfire
Sunburn
Contrary to widely spread and arc flash industry accepted concept of 1.2 cal/cm2 threshold incident energy to 2nd degree burn, I strongly believe that the scope and severity of burn has nothing to do with the amount of incident energy but with the rate the energy has been delivered.
http://www.phpbb.com/
