Arc Flash Forum
Power Factor Correction Capacitors
https://brainfiller.com/arcflashforum/viewtopic.php?f=33&t=5201
Page 1 of 1
Author:  Jim Phillips (brainfiller) [ Sun Nov 03, 2019 3:53 pm ]
Post subject:  Power Factor Correction Capacitors
Capacitors can be a source of an electrical hazard.
This week’s question is about power factor correction capacitors. Here is the question:
Does your company/client(s) have power factor correction capacitors?
Yes - Low Voltage - 1,000 volts and less
Yes - Medium Voltage - above 1000 volts
No
Select up to 2 responses
http://www.phpbb.com/
