It is currently Fri Oct 02, 2026 6:17 pm
What is the highest arc rating of PPE that you/clients use?
8 cal/cm2 3%  3%  [ 1 ]
12 cal/cm2 5%  5%  [ 2 ]
40 cal/cm2 71%  71%  [ 27 ]
65 cal/cm2 8%  8%  [ 3 ]
Over 65 cal/cm2 13%  13%  [ 5 ]
Doesn’t Apply 0%  0%  [ 0 ]
Total votes : 38
 Post subject: Highest Arc Rating of PPE
PostPosted: Sun May 10, 2020 12:48 pm
PPE manufacturers continue to push the envelope of arc ratings with some over 100 cal/cm2
This week’s question is simple.
8 cal/cm2
12 cal/cm2
40 cal/cm2
65 cal/cm2
Over 65 cal/cm2
Doesn’t Apply
 Post subject: Re: Highest Arc Rating of PPE
PostPosted: Mon May 11, 2020 6:06 am
I have customers using 65 and greater PPE, however they have an operational limit of 40. In their minds they need a safety margin.
PostPosted: Mon May 11, 2020 11:30 am
Working with a PPE manufacturer, it seems like 65 is becoming "the new 40"
I'm sure the trend will continue as material gets lighter and better.
