Arc Flash Forum
Arc Flash Manual Calculations using IEEE 1584
https://brainfiller.com/arcflashforum/viewtopic.php?f=33&t=5385
Page 1 of 1
Author:  Jim Phillips (brainfiller) [ Sun Nov 29, 2020 2:26 pm ]
Post subject:  Arc Flash Manual Calculations using IEEE 1584
The equations in the 2018 edition of IEEE 1584 are more complex than the 2002 edition. Have you ever performed arc flash calculations manually using either the 2002 or 2018 edition?
Here is the question:
Have you performed arc flash calculations manually using?
Yes - 2002 Edition IEEE 1584
Yes - 2018 Edition IEEE 1584
Yes – Other methods such as Lee equations
No
Select all that apply
Author:  K. Engholm [ Sun Nov 29, 2020 2:28 pm ]
Post subject:  Re: Arc Flash Manual Calculations using IEEE 1584
Both the 2002 and 2018 calculations in Jim's class. I'm not sure that I have recovered. Quite complex.
Author:  Jim Phillips (brainfiller) [ Sun Nov 29, 2020 4:27 pm ]
Oops. Yes there is quite a bit to it as you found out.
http://www.phpbb.com/
