Arc rated clothing is to be worn when the incident energy level is greater than 1.2 cal/cm^2. NFPA 70E specifically states:
130.7(C)(6) Body Protection. Employees shall wear arc-rated clothing whenever there is possible exposure to an electric arc flash above the threshold incident energy level for a second-degree burn [1.2 cal/cm^2]
Here is the first question of the week for 2021:
Do you/employees/clients wear arc rated clothing around electrical hazards LESS THAN 1.2 cal/cm^2? No Yes – sometimes Yes - always
You can post new topics in this forum You can reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot post attachments in this forum
