Arc Flash Forum
Highest DC Voltage
https://brainfiller.com/arcflashforum/viewtopic.php?f=33&t=5459
Page 1 of 1
Author:  Jim Phillips (brainfiller) [ Sat May 22, 2021 6:52 am ]
Post subject:  Highest DC Voltage
DC voltage continues to be a topic of discussion. Especially areas of higher DC voltage. This week's question is simple:
What is the highest DC voltage that you/clients have?
Less than 50V
50-600V
601-1500V
Greater than 1500V
No DC systems
Author:  Larry Stutts [ Sat May 29, 2021 4:20 am ]
Post subject:  Re: Highest DC Voltage
Actually if you have inverters and 460V in your plant, you have 650+ VDC in your inverter. Most inverters have either the DC bus or the DBR terminals brought out to the terminal strip.
When I was at Parker, we actually used common bus systems. I had several drives in my cubical for assisting customers with product support, and I supplied 460V to one drive and powered up 2 others using that drive's DC Bus. Most drives I did not run a motor on them and only connected to the drive to troubleshoot the customers' configuration problems.
http://www.phpbb.com/
