It is currently Mon Sep 27, 2021 7:10 am
Do you use/specify default enclosure sizes or actual enclosure sizes for arc flash studies?
Default sizes
Actual sizes
A mix
Not sure
Not involved with studies
You may select 1 option
View results
 Post subject: Arc Flash – Modeling Enclosure Size
PostPosted: Sun Jun 27, 2021 12:57 pm
As many know by now, the 2018 Edition of IEEE 1584 provides a method to adjust the incident energy based on the size of the enclosure opening.
Table 8Classes of equipment and typical bus gaps contains enclosure sizes for different voltages and classes of equipment.
Most software defaults to these values in the absence of user specified sizes.
Here is this week’s question:
Default sizes
Actual sizes
A mix
Not sure
Report this post
You can post new topics in this forum
You can reply to topics in this forum
© 2019 Arcflash Forum / Brainfiller, Inc. | P.O. Box 12024 | Scottsdale, AZ 85267 USA | 800-874-8883
