| Have you ever been shocked above 1,000 Volts AC? (and lived) https://brainfiller.com/arcflashforum/viewtopic.php?f=33&t=5505 |
Page 1 of 1 |
| Author: | Jim Phillips (brainfiller) [ Sun Sep 12, 2021 4:42 pm ] |
| Post subject: | Have you ever been shocked above 1,000 Volts AC? (and lived) |
Have you or anyone you know been shocked at voltages above 1kV AC? (and lived to tell about it) The "lived to tell about it" part is obvious since you are still here but what about others? Share your stories! No Yes - Me Yes - someone I know If yes, what was the voltage? |
| Author: | stevenal [ Mon Sep 13, 2021 7:15 am ] |
| Post subject: | Re: Have you ever been shocked above 1,000 Volts AC? (and li |
One of the investigations I was involved with in response to the prior question. 7200 V. The investigation team travelled to the burn unit in order to interview a man with no hands. Isolate, test, and ground folks. |
| Author: | Larry Stutts [ Wed Sep 15, 2021 7:35 am ] |
No, but I was up close and personal to a 6600V arc flash event. The manufacturer assured me that the voltage would only be 600V. It was not - it was 6600V which blew up my Fluke 77 and blew a 1/4 inch divot in the bus bar. |
