It is currently Wed Jul 06, 2022 2:57 am
What is the largest calculated incident energy that you have seen?
Less than 50 cal/cm2 4%  4%  [ 1 ]
50 to 100 cal/cal2 18%  18%  [ 5 ]
100 to 250 cal/cm2 43%  43%  [ 12 ]
Greater than 250 cal/cm2 36%  36%  [ 10 ]
You may select 1 option
Total votes : 28
 Post subject: Largest Incident Energy
PostPosted: Sun Jun 05, 2022 3:43 pm
As a follow up to the last question regarding the largest Arc Flash Boundary, this question is about the largest Incident Energy.
50 to 100 cal/cal2
100 to 250 cal/cm2
Report this post
 Post subject: Re: Largest Incident Energy
PostPosted: Sun Jun 05, 2022 4:20 pm
I saw a label years ago that was a bit above 1000 cal/cm2. Probably a case of "well that's what the software calculated" instead of knowing enough to question the result.
Report this post
PostPosted: Sat Jun 11, 2022 5:59 am
I reviewed a report done by a firm for a company we were hired to do arc flash training for. They had a value of over 12,000 cal/cm^2 in a 115kV switchyard. I pointed out that this was absurd and that the wrong method had been used and that they had the working distance at 18 inches.
Report this post
You can post new topics in this forum
You can reply to topics in this forum
